Showing content with the highest reputation on 03/29/2022 in Posts
  1. Standard Motor Products brand would be my choice if Delphi or ACDelco aren't available.
  2. Just drove my newly acquired 91 very in Florida and drove home 900 miles to PA. I tried to stick to 65 given my unfamiliarity with the mechanicals but it ran flawlessly and I averaged 30 mpg!
  3. 5% discount code 198770038124171508 good until May 1, 2022. Everyone is eligible to use the code.
  4. Just to clarify, a new AC compressor was defective, I could not get an RMA and had to eat return shipping. Just ask Google about RA return issues. Just to clarify, " RockAuto will not accept returns of: Installed parts."
  5. Rock Auto: https://www.rockauto.com/en/catalog/buick,1990,reatta,3.8l+231cid+v6,1019911,electrical-switch+&+relay,oil+pressure+sender+/+switch,4588 EDIT: you can also apply the 5% discount code 198770038124171508 good until May 1, 2022. Type the code in the "How Did You Hear About Us?" box during the purchase process. Everyone is eligible to use the code. Also, the oil pressure sender sensor is different for the '91 Reatta and the '91-'93 Riviera...L27 3800 V6.
  6. I was stationed at the Cape for two years in 66-68, would go up on the barracks roof to watch night launches. Can see them from my garage roof now.
  7. 15 degrees this morning with 4+ inches of snow, on top of the 6" of snow from Sunday morning. Thought we had an early Spring a couple weeks ago with 50 degrees and warming trends with no snow in sight except for the local ski resort. Got anxious so replaced the winter tires on the Reatta with summer treads. So, it will sit for a little while longer until Spring really arrives. Ship's weather forecast was on the mark.
  8. 88-90 uses a 40 psi center sender. 91 uses a 60 psi. Otherwise the same.
  9. After an experience trying to return a defective AC compressor, I will not use Rock Auto.
