Showing content with the highest reputation on 02/15/2022 in Posts
  1. Lookin good! Just don't forget to tighten the cam pulley bolts!
  2. The rear main rubber seal came in this afternoon so I was able to install the crank, hopefully for the last time. Thrust end play was very nice at .0055”. I believe I will double check that tomorrow before installing the piston/rod assemblies. The end play is good but is a bit tighter than I usually see. I plan to loosen the thrust cap a bit and tap the crank back and forth again to be sure the thrust faces are lined up. Starting to look a little more like it should.
  3. Two springs in oil pump kit are probably 40psi relief (softer) and 60 psi relief (harder). I'd probably use the 60 psi spring.
  4. I can't imagine driving a Reatta that many miles. If I did it would take me 3 days. 🙂
