Showing content with the highest reputation on 01/20/2022 in Posts
  1. Yes, good for the A/C system but bad for the crankcase.
  2. Man, Padgett... I agree the car should have been better cared for, but involving Child Protective Services is a bit extreme, isnt it!? /s
  3. When filling the gas tank, I also add a stabilizer. I run it for 5 minutes or so to get the stabilizer up to the injectors. Then I do not run the car until Spring. I too put on a battery trickle charger.
  4. I just fill my car with gas and park it for the winter [or in the case of my winter Reatta, for the summer]. I don't fire it up, but I do disconnect the battery.
  5. If it has the Magnavox ignition, the original single coil block style, try closing up the spark plug gap to something in the .042"-.048" range. If it is a misfire under load, that may help. Incidentally, I just run Autolite copper core plugs, my preferred type from way back, but then again, I actually change whole engines somewhat regularly🙄
