Showing content with the highest reputation on 01/09/2022 in Posts
  1. Ignition module is more likely to fail than the coil pack on a Magnavox. Was the ICM replaced as well as the coils? Did you check for vacuum at the black line connected to the center of the bunch of vacuum tubing on the bottom of the HVAC Programmer, (engine running)? It is the main feed to the controller and the other end is at the tee shown in Ronnie's photograph. To test the air diverter door for the HVAC system, you must change the temperature on the climate control, up and down, and observe the rod from the controller through the glove box opening. It does not move rapidly but it should move visibly when the temperature is adjusted. If it doesn't, that may be part of the communication issue.
  2. Here's something I'll bet you have never heard of before. My wife asked me to take her minivan to the car wash and be sure to get the "soft touch" wash which is the rotating cloth strips that clean your car. I read the warnings about not being responsible for loos items, antennas, mirrors etc so I folded the mirrors in and proceeded to get my car washed. About halfway through the cycle I felt droplets of water and thinking that the sunroof was just cracked open, pressed the button to close it [it was closed]. In the process I looked over my right shoulder and saw that somehow the brush had activated the sliding passenger door and now the door was completely open and the brush had come partly into the cabin but wanted to leave but couldn't. It was hooked on the inside edge of the door and pulled it completely off and finished washing the car [final rinse] spraying water into the cabin. I quickly went outside the car and was able to get the door somewhat in place , enough to get to the store and explain what happened. As this was a "big box" retailer they directed me to the main store and ask for the manager which I did. Fortunately they also had an automotive repair area and I was able to bring the car in so the manager could fill out an accident report and take pictures. I was able to get the door completely situated in the track, closed and then we duck taped the entire door so it would be air tight and not come off. Tomorrow I go for estimates and hope we can get the repairs done before I leave for Texas. The retailer has assured me that their insurance company will be contacting me and that they will pay the claim. I am pretty sure that will happen, but we will see. I am also contacting my company as well.
