Showing content with the highest reputation on 01/01/2022 in Posts
  1. Obviously not a photo from under the car but this may give some clues. I don’t believe a factory reproduction system is being made.
  2. Maybe it wasn't bad gas after all. I was talking to Bob a couple of days ago and I mentioned I have this habit of filling the car as full as possible [way past the clicks of the gas pumps]. Maybe I had so much extra gas that it got into the charcoal filter and caused my problem. At any rate I am a number of fills into it and even my wife says the car drives like it should.
  3. Local temps have been fluctuating and humidity has gone up over the last few day causing thick fog each night. Went into the igloo to check on my Reatta. All is still ok...just waiting for April. BTW, I had a chance to check the miles driven for 2021...only 618 miles for the whole year.
  4. If you remove the whole exhaust system grind out the restriction that is in the manifold where the pipe bolts up if it has excess material left over from casting.
  5. 618 miles for the whole year is hardly driving it. I would think that you could use it for errands or something to get that over 1000 miles. Ronnie, the rubber doesn't freeze on this one like the old Black that 2seaters son now has. That one would freeze up just sitting in the driveway overnight. The longer that one is gone the less I miss it...
  6. Do you have to dry the rubber to keep the doors from freezing shut? It's been unusually warm here. It was over 60 here today. Predicted to be 76 here tomorrow with rain then dropping down to the 30s by Monday. We have crazy weather swings here in Tennessee. Even with the warm weather I've not been out of the house today. Trying to recover from aches and pains after changing the radiator in my daughter's Camry yesterday. Staying bent over for a couple of hours isn't good for a bad back. Saved her $300 in labor to pay someone else to do it so I guess it was worth it. 🙂
