Showing content with the highest reputation on 12/20/2021 in Posts
  1. I agree, the Right Stuff is good stuff😉 The filling the badly eroded areas just seemed obvious to me. Perfect application since it only needs to provide a smooth surface, no real pressure and it is essentially captive.
  2. I should have said, the alternative ALSO works well, not to suggest Fel Pro is substandard, because I use them too. As a matter of fact, if they are not damaged like in the original photos, they can be reused if the silicone beads are in good shape.
  3. Generally I like Fel Pro as well except their head gasket, which has too large of bore, costing compression ratio. For head gaskets, Victor Reinz makes the OE style with the correct bore size and shape. They also have a different style intake manifold gasket which works well in my experience. It doesn’t have the silicone sealing beads which can fall right back into the eroded areas. It is just an alternate choice if needed.
