Showing content with the highest reputation on 11/05/2021 in Posts
  1. The 88-90 engines are different then the '91. However if you went to www.car-part.com you should find what you are looking for.
  2. Fuel problem solved Jim Finn saved me he had the parts I needed now I can put the reatta back together.
  3. I would replace some of the bulbs to make the flasher click. Then you can reach up there and feel around until you feel the clicking with your hand, then pull it down. If the directional flasher didn't work then use the emergency flasher and do the same as stated above. I would have the replacement flashers in hand before finishing the project [the reinstallation of the LED bulbs with the new flashers].
