Showing content with the highest reputation on 10/31/2021 in Posts
  1. I posted the following under a different topic, but cut and pasted below since it seems to put a final touch on most of my issues. Still have issues with the Cruise Control servo, but that's another page...... The MAF was replaced (due to code (E034) and then I got a code for the Cam Sensor (E041). Replaced both which were of no help. I then got a code for the Ignition System (E042) and after checking and finding that two cylinders were not getting spark, I then replaced the Ignition coil and ignition control module. The car now runs great (at least for the 25-30 miles that I've driven since). Turns out, I suspect, that the ICM was probably the original culprit all along in spite of the E034 and E041 codes. Funny thing is that the codes popped up one at a time and not all at once. Had the E042 code shown up first, a replacement ICM and coil pack may have cured the poor performance right off the bat. As it is, I spent way too much on trouble shooting, especially with the replacement MAF (and also the catalytic converter) before checking the ignition coils. I'd suggest that anyone encountering extremely poor performance start off by testing the ignition coil and ICM.
  2. B671 - cruise, server position servo circuit. First I'd just R&R the connector. If doesn't fix is either wiring or the cruise servo itself. Millions in GM cars of the period.
