Showing content with the highest reputation on 10/06/2021 in Posts
  1. Met up with 2seater yesterday for lunch. We attracted a bit of attention with our two Reattas parked side by side. We ate a "Chedder's" a chain restaurant somewhat like a Perkins. We had a two hour lunch talking about Reattas, my two mechanic buddies [Kendall and Bob and how lucky I am to have them as both friends and help mates] and exchanging ideas about our cars. I had a great time.
    5 points
  2. Sounds like a lot of fun. It must be nice to have some Reatta buddies close by.
  3. Can't get to the photocell any other way then through the top. If you do go through the top using the tool you won't damage the dash, but you may break a tab or two on the pad that holds the pad into the dash because after all the plastic is over 30 years old. Just go slow and be careful. The grill and pad are still readily available while the dash is the hardest to replace. Jim Finn or Marck [at East Coast Reatta] has those parts but a dash is way more expensive and time consuming to replace. And while you are in the top of the dash remove the inverter located right about the vin tag is and push it down through the dash towards the bottom. If the inverter ever goes out you will be able to then get at it from the bottom of the dash without going through the top of the dash pad again.
