Showing content with the highest reputation on 07/29/2021 in Posts
  1. I received my new debit card today with the photo of my Reatta on it. I'm very happy with the way it turned out and it got here sooner than expected. It looks exactly like the card preview I posted at the beginning of this thread. Unlike my current card, the new card number is on the back so it doesn't screw up the looks of the card any more than necessary. If it didn't have that electronic chip on the front it would be perfect.
  2. Thanks guys. I'm working on it.
  3. Welcome to the forum! I just answered your question on another forum. Here is the answer again. Remote Transmitter (RKE) Replacements
  4. 1 point
  5. Thanks to the ROJ, I am learning a lot about how the touchscreen diagnostics work and can access /clear codes. I need to do more homework about overrides and all the crazy numbers. I feel like I have really narrowed down my current issue with y’all’s help.
  6. The Reatta onboard diagnostic system is your best tool when troubleshooting your Reatta. Everything you need to know can be found here on ROJ if you take the time to learn about it. Just click on the Diagnostics menu at the top of this page. Once you learn how to access diagnostics I recommend learning how to check trouble codes first. Finding the trouble codes stored in diagnostics is a good starting point when you are trying to figure out a problem. Then get to know the Diagnostics booklet listed in the diagnostics menu. It will tell you all about how to use the onboard diagnostics to read data and how to use overrides to do tests that are really helpful in figuring out a problem. Play with the onboard diagnostics all you want. You can't hurt a thing and no changes you make are permanent. When you turn the key off and back on all changes you make with overrides are gone.
  7. Back safe and sound and 2021 PVGP in the books!!!!!
