Showing content with the highest reputation on 07/11/2021 in Posts
  1. My OTC 2000 can read/clear/override everything the CRT can. For ABS it just says what wires to jumper.
  2. Just to clarify, the photo shows the pad on the ICM connection. I have ordered an OEM Magnavox ICM since I’ve already invested in the Magnavox coil pack. Thanks again to Ronnie and Padgett for your help.
  3. This is mixing and matching a number of things. OK the 1.5-2 seconds is the prime shot sent when the ignition is turned on. ONCE. If the engine does not start the oil pressure never comes up (unless you crank for a while) and the pump does not turn on. If you have no spark that is a different problem and one that needs to be fixed before worrying about the fuel pump.
  4. No, just replaced Magnavox with Delco. Needed to replace a couple of coils but no big.
  5. Been a while but think it is the orange thingie in the picture. BTW there are three nuts that hold the ICM on. Two are easy, one is near impossible. I usually leave that one off.
