Showing content with the highest reputation on 05/01/2021 in Posts
  1. A few more questions to test the BCM. With the key in the RUN position: Do the fog lights come on when you push the button on the console? Do the parking lights come on when the fog lights are burning and the key is in the run position? (Don't turn on the parking lights using the headlight switch.) When you have the headlights on are you able to switch from low to high beams? You really should stick with the problems you started this topic about originally instead of digging up more problems along the way like the coils. It will be less confusing if you will start a new topic for each problem you encounter.
