Showing content with the highest reputation on 04/06/2021 in Posts
  1. 3 points
  2. It's too Pharr away... Besides I am downsizing from a high of 5 Reattas.
  3. Thanks Ronnie, you're very kind. Unlike yourself, I don't have nearly as much experience a mechanic but I still should have known what I was doing. I have quite a bit to do around the house tomorrow but will check all the other fuses on Wednesday, weather permitting. Once the replacement positive terminal arrives from Jim I'll install it and, cringing with crossed fingers, connect the battery and let you know what happens (or doesn't happen.) Regardless of the outcome, I'm committed to seeing this through. Again, many thanks, you've made be feel little better.
  4. Thanks Ronnie. I believe I overstated the leaking issue. One of the reasons I added so much brake fluid was because when one swaps the pump/motor brake fluid is lost. However I did go out to the car just now and the bottom of the pump is dry, so I have that going for me, which is nice. The last 10 words above are from a movie... anyone know which one?
