Showing content with the highest reputation on 01/04/2021 in Posts
  1. Are you asking about the "R" emblem in the center, or the entire cap that pries off to expose the lug nuts? If it is the entire cap, that would be odd as it is a sort of friction fit. Is the steel spring in the correct place inside the cap? I have seen the metal outer casing, the shiny part you see, become loose on the black or gray plastic body. It is crimped around the edges of the cap. I have never actually repaired one like that if it is the issue so I hesitate to suggest what may work.
