Showing content with the highest reputation on 11/25/2020 in Posts
  1. The procedure is the same for all 4 years. There may have been different bushings for the front two but as our cars are so old and those parts are discontinued we are now using the one size fits all procedure. Be sure to get the correct bolts as the ones in the Dorman kit are the wrong thread.
  2. Tomorrow is the big day for the rack and tires. I have an 8:00 am appointment. Should be done by noon. On a side note I keep looking at those wheels [8 spoke 4 for $80.00] but I just don't drive enough to warrant a second set of rims/tires as the Red and the 'vert have Michelin Defenders with an 80,000 mile warranty.
  3. It might be the crankshaft position sensor. It produces two signals that are needed for the engine to run correctly. Maybe if one signal is missing the engine will start through the ICM but not continue to run without the other signal when the ECM takes control of timing and fuel.
  4. The shop called to say that the pressure hose needs to be replaced. Nothing in town and me with no inventory, so the car won't be done until Monday because of Thanksgiving.
