Showing content with the highest reputation on 10/17/2020 in Posts
  1. First step is to spray some silicon spray or WD40 in between the channel where the glass runs up and down. It can make quite a difference in how the windows operate. In my opinion the Reatta window motors aren't overly powerful even when new. If that doesn't help you may have to remove the door panels to get at the window channels better and/or replace the motors.
  2. That relay may be bolted in place high up to the left side of the steering column dash mounting bracket. In my case it was hanging loose, probably as a result of swapping dashes. I know it is inconvenient, but removing the drivers seat, panels under the dash and dropping the steering column may gain access. I fashioned a jumper from a small piece of copper wire, maybe 14ga, and flattened the ends at right angles to each other to resemble a staple. This inserts into the relay socket between pins 30 and 87a. That's the one in the middle and the one that is at right angles to the rest. The relay can stay in place if you can get the socket disconnected and pulled down. Failing the above, if you can at least see the harness, you want to connect the two yellow wires together that connect to that relay.
