Thank you Ronnie -
I finally went out and pumped my brake pedal 25 times then turned the ignition ON and started the engine and the anti lock amber light stayed ON. I checked the brake fluid level and it was about 1/2" low, added fluid level to the max level mark. With the ignition OFF I pumped 25 times then turned the ignition ON and started the engine and again the anti lock amber lamp stayed ON. I checked the reservoir and it is now 1/2" down from the max level mark. I pumped 25 times then started the engine and the anti lock amber lamp went OUT and stayed OFF. SUCCESS !!!
What all this resulted from is my '89 is a garage queen and over the previous 2 years has had very few miles and the accumulator nitrogen pressure had slowly forced the brake fluid back to the reservoir plus the fluid level down kept the anti lock amber lamp ON.
Once again thank you Ronnie
Woody
89 MAUI
