Showing content with the highest reputation on 09/16/2020 in Posts
  1. UP-Date: Idle problem. (fast 2000rpm) Changed throttle position sensor, No change. Changed all other sensors. No change. After reading the fine print in the shop manual I discovered that the throttle sensor must be adjusted thru the computer. o be set to the correct voltage. Takes two people, one in the car to watch computer and one to adjust the sensor. I had to bend the tab on the sensor to get the correct voltage. Guess what, the correct idle speed.
    4 points
  2. It appears the update was successful. The forum looks a little different but should work the same as it did before. If you encounter any problems or see something that isn't quite right please let me know.
  3. New member status provided a chuckle as I’m thinking 2001 was when I started enjoying this forum. But then they say memory’s the 2nd thing to go after 60 ?
  4. Not a problem at all. We all love to see beautiful cars and that certainly is a beautiful car.
