Showing content with the highest reputation on 08/27/2020 in Posts
  1. The carb cleaner as you know is just to loosen the gunk and then starts to evaporate off. The water then nuetralizes the carb spray and works off the gunk. The air is to dry everything so the next spray of carb cleaner works it's magic again. In my experience there isn't enough carb cleaner sprayed at any one time to get to the carpet. I wish I could take credit for this, but it was Kendall that showed me the system and how well it works.
  2. Sounds like the last of the issues are in sight. I'm glad for you guys. I have a system for cleaning inside the plenum. I remove the fan and the module. Drop a light down through the module so you can see what you are doing and start by spraying the evaporator with carb cleaner. Then follow with a spray of water from your garden hose, then blow dry with the use of an air compressor. Repeat until clean. It works great and the change in air through the vents is great.
  3. I only saw a portion of the photo on my phone and the Rock Auto label didn’t show until I moved it and scanned the whole thing?
  4. I hope Rock doesn't mind me using their photo for illustration purposes. After all it might lead to them selling you a switch. ?
  5. Man, you have some of the best photos! It is fairly easy to see, not so easy to touch. It is up high and almost hard against the firewall, but with the provided detail, there might be a chance. There was one other thing to share that I have rarely seen. The grandson got the owners manual out of the car looking up bulbs and he left it on the cottage. I looked through the contents and some loose papers this morning. I found the original window sticker and two copies of the line broadcast sheet, the actual build sheet, in the folder. I collected the loose papers and put them in a ziplock bag with the owners manual. A nice and unusual find for me. Incidentally, the original list was $27,250, or $56k today. Cupholders not included ?
