Showing content with the highest reputation on 07/22/2020 in Posts
  1. 1983 Buick Reatta full size clay If you zoom in it says GSX on the front of the door. This is the only true GSX Reatta made by Buick that I have seen.
  2. The used fuel pump sending unit is sold, however an aftermarket exact replacement is the Dorman #692-102. Just look up a 1988 Cadillac Eldorado and you will see the Dorman and a couple of other brands. the Dorman has soldered electrical connections [inside the tank] and the original factory unit does not. Only issue I have is that the Dorman sending unit reads to empty tank faster then the factory one and "leaves" gas in the tank [about 3-4 gallons] at empty. Speculation between the repair shop, Ronnie, 2seater and myself is that it reads empty early is to save the fuel pump from overheating as the fuel is used to keep the fuel pump cool. This is not the first time we have experienced having to list another car to get "obsolete" replacement parts for our Reattas. Another no cost service from your no cost techs at the Reatta Owners forum...
