Showing content with the highest reputation on 06/16/2020 in Posts
  1. I would assume the CPS is bad if it didn't test the same way mine did. But I've never tested a bad one so I couldn't say for sure.
  2. 1 point
  3. Most multimeters, digital or analog, can't react fast enough to the almost instantaneous rise and fall of the 18x signal. Nor can a 12 volt light bulb in a standard test light. That is the reason I used a LED to do the test in the tutorial. A LED can react almost instantly. You might be able to set your meter on millivolts and see a blip but I couldn't with my meters. I have an analog meter with a needle, a cheap digital and a really good digital meter and none of them would detect the 18x signal. When I did the test on my car it was starting and running fine so I know the signal was there. I just couldn't see it with my meter. Believe me... I like to do things the easiest way possible. If I could have done the tests reliably with a multimeter I wouldn't have recommended making a LED tester just to do the tests on the crank sensor. I don't think I would dive in and replace the crank sensor based on the readings with a meter until I was certain it was giving me an accurate reading of the 18x signal. I recommend spending a few minutes and a couple of bucks to make the LED tester.
  4. I would agree the test light is simpler and perhaps easier than the voltmeter plus it is a simple on-off test that doesn’t require the nuance of the meter. I am guessing what you are calling a CPS shield is the bracket for the little damper shock on the engine? Early 88’s didn’t have that damper but was added as a running change so GM must have felt it was an improvement. Maybe removed to change the serpentine belt? I think we have identified up to three different harmonic damper bolt configurations used over the years but not a definite progression on their use and appear to be interchangeable. Different head sizes and shaft configuration, some have a reduced diameter section and others are full size over their length?
