Showing content with the highest reputation on 02/11/2020 in Posts
  1. Yes, I skimmed through it and it is certainly related to the survey and I think there was also a board meeting just recently as well. A couple weeks back I read through a long thread in the first subject in the home screen, General I believe, and it had an disagreement going on between Peter G and some poster I don't remember, and a couple other moderators stepped in as well, all about this exact subject. My understanding at that time was the AACA portion was more restrictive than the sub forums, especially if the forum title was for modified and otherwise non pure stock.
  2. I think the AACA main forum is supposed to be pure and a little leeway will be given in the other sub forums.
  3. Here are some pics of the O2 sensor, and removing it: Came out real easy....not stuck like some are. I used the 22mm O2 socket which fit perfect: Not too dirty, but some black carbon did come out when using a wire brush: Cleaned: Stamped "AC Spary".......Could this be original "fac-tree" equipment? New O2 Sensor should be here in a couple days.
  4. How the Teves ABS system works This is a good video that I found on YouTube that gives a good description of how the Teves MK-II ABS system works. It is on a Chrysler vehicle but it is the same ABS system that is used on the Buick Reatta. You can learn a lot from it.
