Showing content with the highest reputation on 01/30/2020 in Posts
  1. I forgot about the magnetic photos. I wonder how many different ones there are? I have 30 of them in one place and only one duplicate. I just looked and maybe answered my own question, at least partially. Lowest number I have is #1, a Camaro, and the other end is #170, a Ford five ton truck and my duplicate is ironically enough, a full size 60's Buick, #144.
  2. At times, Rock Auto sends out a 5% discount code to its users. Any/all folks are OK to use the discount code. Normally, over at the Riv Performance Forum (http://rivperformance.editboard.com/forum) you can find that someone has listed the most recent code that's good to use until a prescribed expiration date. You don't have to be a frequent/past/present Rock Auto user to take advantage of the discount. However, in order to acquire the code you need to have a Riv Performance Forum ID/Password. When ordering at Rock Auto, there is a box labeled "How did you hear about us" on the Payment/Shipping screen. That's where you enter the discount code.
  3. After you order the first item you will see a little truck next to some of the items you also might be interested in. That tells you it is the same warehouse as items you have in your cart. So that means that sometimes a lower cost item from a different warehouse might be more expensive then a higher priced item from the same warehouse because of freight. Then once you have your order set what I then do is go back and buy other items that I can add to the order that are from the same warehouses that may not add to the freight charge. These items might be oil/air filters, wiper blades, relays, brake pads, spark plugs/wires, etc. As long as the freight charge doesn't increase I consider it a good deal. Of course if you don't drive many miles that may not be as important, but for me it makes sense. I just placed an order an did just that. I started needing oil pan gaskets and timing chain gasket set [2 each]. Then I added front brake lines, front brake rotors and pads, wiper blades, oil filters. Then I added an air filter for my wife's Enclave and then oil/air/cabin filter for my daughter's KIA. The order was about $125.00 with about $27.00 of that in freight but look at all the stuff I got and will probably use in the next 6 months.
  4. They do, but that makes no difference to Wisconsin residents as Amazon charges us sales tax also because they have a warehouse here. Pay close attention to shipping charges from Rock Auto. Before you know it you could be ordering from 3-4 different warehouses. That is where the real costs are.
