Showing content with the highest reputation on 12/17/2019 in Posts
  1. Here are a few photos that show how I do it. That doesn't mean it's the best way but it works for me.
  2. The abs valve allows the brake pressure from the pump to be maintained while directing the fluid to both rear tires. Do not worry about the fluid that is in the abs valve as it will be changed through the change out of fluid. The abs valve is physically located in front of the rear drivers side tire.
  3. I know this may sound odd, and it is a different type of system. The rear brakes use fluid from pressure pump directly, modulated through the brake pedal, hence there is a direct path from the reservoir through the pump and out to the rear brakes. The front brakes are more conventional with the pump supplying boost pressure to the master cylinder which amplifies brake force from the pedal. Due to the design of the system, if the boost pump fails and the accumulator is depleted, there is no rear braking, only the front brakes in non-power mode.
