Showing content with the highest reputation on 12/16/2019 in Posts
  1. The pedal may feel differently with the accumulator empty vs with pressure in the accumulator but it should work either way. on the fronts I would do it with the key on. Start with the wheel that is the farthest from the master cylinder and continue with the next wheel farthest away until you have them all done. Be sure you don't ever let the reservoir run empty. If you do air will get in the pump and it might cause you lots of headaches.
