Showing content with the highest reputation on 12/15/2019 in Posts
  1. That would be most excellent. I know I desire to be accurate regarding answers so.... With accuracy in mind, I just looked at that '95 S/C engine, the last year of the Series 1, and it sure appears to have the same sub-harness as the '90 and the connector is located behind the power steering pump. Much of the rest of the wiring on the rear was cut off since this is a junkyard engine, but the portion that runs forward of the plenum is intact and does contain connections for the injectors, tps, maf etc.. I am pretty sure there was no disconnect between the firewall and the engine or they would have unsnapped it as was done with other connectors. One thing to note is the '91 does not have EGR so that wiring may or may not be present but was added back on later models.
