Showing content with the highest reputation on 11/21/2019 in Posts
  1. Ronnie thanks for the test info! I very much appreciate the effort. So I installed my original ECM (which has a remanufactured labe)l and went for a test drive of about 15 miles. I had purchased another ECM to verify that my IPC issue was not related to the ECM - and it wasn't. Same exact response. I literally rode home without touching the gas pedal and used brake only to get around the curves. However, when I came to a stop in the driveway, it did drop to 725 rpm much quicker than it did yesterday. Ronnie I see the exact same numbers that you see and have the same responses to override controls. Tomorrow I am going to run through the sensor test as suggested by 2Seater. This seems to be movement related to the transmission. I might even try jacking up the front wheels off the ground and see if I can duplicate the condition in the garage. (Note: I will be backing the car in so that it is facing out the door and not towards my BMW K1200R Sport!!)
  2. I have extra ECMs available for sale. If interested e mail me at; lemke1044@aol.com
