Showing content with the highest reputation on 08/15/2019 in Posts
  1. I believe the Wabco STC2784 is a viable replacement but I don't have a list of vendors. A quick search showed it was available on Amazon but not the best price. I am using the Hydac unit from Spinning Wheels and have tested a few others, but have not had the opportunity for the Wabco unit.
  2. Ronnie has covered the bases pretty well. Disconnecting the MAF shouldn't include disconnecting the TPS, the ECM needs some form of reference to indicate increased throttle. I have seen floating data like the 20rpm indication with engine off before, it may also show in other areas, but should not do so while running. Eliminate possible fuel pressure problem first.
  3. Maybe bad gas? Water could have settled to the bottom of the tank while it was parked.
