- Last week
I haven't been doing much with my Reatta ('90 Convertible) but while I'm getting work done on the seats I'm tackling the interior. I've been working on removing the carpet but I've hit an obstacle when it comes to the floor carpet. Does anyone know how to safely remove this piece? It's the only thing holding the carpet down now, so once its gone I can really get to work haha.
Ohjai replied to DAVES89's topic in Reatta Owners Journal Forum
Ship, I am a Blessed man, I still get up under the dash,, a bit of an issue getting back out and my eyes don't always see what I am looking for, and I turned 85 in Feb. -
Oil leak after replacing timing chain
Ronnie replied to rpetry's topic in Reatta Owners Journal Forum
Yes, and the engine block is machined differently to accept either the counterbore or the chamfered style tensioner. I agree with 2seater that the incorrect tensioner was used and the bolt it hitting the cover. -
2seater replied to rpetry's topic in Reatta Owners Journal Forum
It is no secret I do not like the new style chain damper because it fits lines up poorly on the chain, but it doesn't usually cause a direct fitment issue. There are two options for the damper, chamfered and countersunk bolts. I would bet the bolt is hitting the cover -
rogold replied to rpetry's topic in Reatta Owners Journal Forum
Rock Auto shows 2 different designs, one is for a chamfered hole, one for a counterbored hole 1988 BUICK REATTA 3.8L 231cid V6 Timing Chain Guide / Damper | RockAuto -
Hi, everyone! I replaced my timiing chain and sprockets on my 1988 Reatta yesterday, and also the chain damper which was pretty worn. I got the newer version of the damper, because that seems to be the only part available. Well, the engine starts with no error, however it is leaking oil like crazy on the left side of the timing cover just below the water pump. I can see it coming out but for the life of me, I can't tell why other than there is a gap somehow. I did notice the newer damper is slight taller than the old but not so that it should have made a difference. Has anyone had issues with the new damper or have any ideas on why I am getting a big leak (obviously something isn't sealed there)? I am a little forlorn about the possibility of pulling that timing cover off again as I had a heck of a time with it. I'm guessing I'm going to have to do that.
Thank you! I will chase down a new one. You guys are great!
ship replied to DAVES89's topic in Reatta Owners Journal Forum
You guys are still "youngsters" in my book. I turn 75 next week.... knees and back wreak havoc with me when just detailing interior of my Reatta; never mind trying to change a tire! -
Welcome to the club buddy. You are in the phase of where it hurts after you do that stuff. The next phase of getting old is having to hold on to something when you get up and down to keep from putting too much stress on knees and other parts. Ask me how I know... 🙂 I can still do most of my own routine maintenance that requires getting up and down but I don't like to do it any more than I have to. -
Not really a Reatta story but I did take the Red to the local fast food restaurant for lunch when I got done. I'm really feeling my age as I did front and rear brakes on my neighbor's sister's Dodge Grand Caravan. Not so much the work but the constant up/down moving the floor jack, placing jack stands, getting different tools, cleaning caliper brackets, running for parts as the car called for different pads and rotors then I thought. Time keeps moving on... -
Looking for PDF copy of 1989 Reatta Service Manual
lent0n posted a topic in Reatta Owners Journal Forum
Can't seem to find any online from sites I normally purchase from, if anyone can help it would be much appreciated! -
Certainly better. Where is the inlet air temperature sensor? It should be in the actual air stream and you can read it to compare to the ambient sensor in front of the radiator. Any sort of baffle or wall to minimize the heat from engine being drawn in will help too.
Alright the final form of the intake is installed with the maf sensor in place. Just gat a long bend pipe and cut off the excess and she fits great under that support bar!
Update on the brake fluid level and pressure test. At this point I do not see any leaks at the suggested areas so I am in monitor mode now. I did break out my test gauge and as near as I can tell, my Hydac accumulator is in the 750-800psi precharge range. Not perfect, but still pretty good. The gauge flashes to ~800psi when the circulating valve is closed on the way up and drops off completely at ~750psi on the way down. The operating pressures observed for pump on and off are in the correct range at ~2,650psi shut off and ~2000psi for pump on. All appears well at this time. - Earlier
To the best of my knowledge, only the 90 and newer use the short harness. The touchscreen cars have a different wiring scheme.
Last week I had to remove the compressor because it was leaking, and decided to try removing it without removing the radiator this time. I was able to move it toward the battery, rotate it 90 degrees upward, and out. -
Anthony started following New winter car
Wow, I wish I'd known that. I spent $140 on just the ICM pigtail, and all the wires were white 🤦♂️
It really wasn't until I put my known good ignition module on that I thought it was something to do with the wiring. Before I was swapping first coils and then the ignition module and old coils and finally a known good module/coil set up that I knew something else was wrong. First test was just disconnect the harness and reattach it and it would fire. Next time wiggle the wires at the ignition module without removing the connector and it would fire. I then took a close look at the harness and saw it was only a 3' harness with 5 connectors. Went to the Buick dealer and one left in the country at $200.00. Went to Rock Auto and a Dorman was $85.00. Amazon was $110.00 for the same Dorman. The Dorman was a nice replacement, looked to be of good quality. Only connector that gave me trouble was the crank sensor. It started going on so hard that I had Kendall make the connection as I didn't want to damage the pins on the crank sensor causing more work. Only things I had to remove to get at everything was the engine shroud, serpentine belt, and water pump pully. Front to back time about 45 minutes. Gotta love the 3.8!
2Seater, I've been using a battery maintainer on each of my cars that get stored in the Winter for a number of years now. In my opinion it beats having to go through the "learning process" with each car every Spring. Also, I've never had any issue with "over/under charge" of each car's battery despite a few rumors that have crossed my way over the years. -
Doing it on a Ranger makes no sense but doing it on a Mustang that is supposedly a "high performance car" is just plain crazy. It's got a fiberglass hood and trunk lid, aluminum overhead cam heads, limited slip differential, dual exhaust from front to back and huge roll bars for handling. Then they install a fake oil pressure gauge? Whoever came up with that idea should have been fired. -
Yup, found the same thing about my 97 Ranger, and you can’t just replace the sender with a true variable one either. The system won’t allow for it. The only solution is a stand alone gauge😑 -
I'll bet that was it. I had a similar thing happen on a Chevy Cavalier. Wires going between the ECM and the ignition pickup inside the distributor (same purpose as crankshaft position sensor) ran under the battery tray. Battery acid had run down and got into the wiring harness underneath the battery where those wires were. The battery acid had soaked the wires and discolored them shorting them out even though the insulation was still intact. The voltage from the pickup in the distributor was so low (0.9 volts I believe) that almost anything will short it out and cause the engine to stop running. I worked on it every evening after work for a week before I figured out what was causing the engine to randomly quit running. I replaced those wires and the problem was fixed.
I'm no longer able to tell stories about troubleshooting my Reatta but I do have an interesting troubleshooting story about me wasting several hours of my time by making an assumption about how something works. Since I got my GT I always wondered why the oil pressure gauge went up half way to the "normal" position when I started the engine cold or hot and stayed there all the time no matter what the RPM. That seemed odd to me so I temporarily installed a mechanical oil pressure gauge on the engine to make sure I had good oil pressure. The mechanical gauge showed 75 psi at idle on a cold start and then it went down to 35 psi at idle when fully warmed up. Spec in the repair manual is 20-45 psi at 1500 RPM when hot. I had 49 psi at 1500 so oil pressure is great. So, in typical Reatta thinking, I assumed the oil pressure sending unit was bad and replaced it with a new one. Still the gauge in the instrument panel read "normal" all the time. Bad gauge? NO. After reading on the forums I discovered all GTs of similar model years as mine have the same "normal" reading without the needle ever moving just like mine. The gauge isn't a real oil pressure gauge at all. IT'S AN IDIOT LIGHT in the form of a needle on the instrument cluster gauge. The oil pressure sender I replaced is just a switch that closes above 6 psi and tells the needle in the gauge to move to the normal position. Either the gauge reads "0" as it does when the engine is off, or "normal" no matter what the real oil pressure is as long as it's over 6 psi. For me, the oil pressure gauge is the most important gauge on the dash of a car. You can't even make the gauge on my GT work as a normal oil pressure gauge that actually reads pressure by installing a real oil pressure sending unit. It wasn't designed to do that. What were the fools at Ford thinking when they put a oil pressure gauge like this in a Mustang? Even a real idiot light would be better than this stupid gauge design. Rant over 🙂 -
Yesterday the car threw codes again so over by Kendall to get it read and cleared. Fortunately my Dorman harness arrived and I replaced that as well. Cleared the codes and once again they are gone. Took a close look at the removed original harness and saw that where the harness goes to the crank and cam sensor it goes between the heater hose and engine block. The loom was melted away and the wires were very stiff and partially melted together. So I really think this is it and hopefully I am good from here on out. I did cut off the plugs making extra short pigtails because as Kendall said it never hurts to have extra pigtails laying around on a 25 [Regal] year old car and two 30 plus [Reatta] year old cars.
I ended up having the compressor, dryer and the little valve in the line replaced. As I was sitting on about 10 cans of R-12 I stayed with the r-12. Also had the antifreeze flushed and filled as the radiator is in the way of getting the compressor out. Ready for spring!
3895 -
2166 -
1972 -
602 -
143 -
130
