RemSteele Posted October 16, 2020 Share Posted October 16, 2020 Hi team, Please help me to understand if the solution is motor replacement. Right tinted window very slow opening and closing. Left tinted window will stop and start to complete process. What's the repair? Thanks Reatta team RJ Link to comment Share on other sites More sharing options...
Ronnie Posted October 17, 2020 Share Posted October 17, 2020 First step is to spray some silicon spray or WD40 in between the channel where the glass runs up and down. It can make quite a difference in how the windows operate. In my opinion the Reatta window motors aren't overly powerful even when new. If that doesn't help you may have to remove the door panels to get at the window channels better and/or replace the motors. 1 Link to comment Share on other sites More sharing options...
RemSteele Posted October 17, 2020 Topic Author Share Posted October 17, 2020 Thanks for the reply. Kinda made mess trying to spray the window tracks. Going to plan day to remove the panels. Link to comment Share on other sites More sharing options...
RemSteele Posted October 26, 2020 Topic Author Share Posted October 26, 2020 Concerned. I was able to remove door panel with better access to window track. Not good results. window lifts remain slow (stops sometimes). What am I missing? Thanks RJ Link to comment Share on other sites More sharing options...
Ronnie Posted October 26, 2020 Share Posted October 26, 2020 I don't know. There is supposed to be a spring on the window mechanism that helps compensate for the weight of the window glass. It would be odd for both windows to have a problem with the spring but that is all I can think of unless both motors are bad. Link to comment Share on other sites More sharing options...
2seater Posted October 26, 2020 Share Posted October 26, 2020 True that the Reatta windows aren't fast movers to start with but if they actually stop, is there any sound that accompanies that? Is the passengers window being operated from the passengers door? If so, it is very odd to have two motors go bad at the same time. Having found broken wires in the hinge areas of three different cars, always the drivers side, I would check for proper power and ground. Link to comment Share on other sites More sharing options...
RemSteele Posted October 27, 2020 Topic Author Share Posted October 27, 2020 Team, Thanks for the response. Rainy weather today has prevented me from testing them. As luck would have it. My headlight (left) decided to fail. On the fence on rebuild or purchase remanufactured. Any advice? Thanks, RJ Link to comment Share on other sites More sharing options...
Ronnie Posted October 27, 2020 Share Posted October 27, 2020 1 hour ago, RemSteele said: As luck would have it. My headlight (left) decided to fail. On the fence on rebuild or purchase remanufactured. Any advice? Contact Barney Eaton. He offers the headlight repair kits and I believe he has rebuilt motors at a good price. barney@texas.net Tell him Ronnie sent you. 1 1 Link to comment Share on other sites More sharing options...
RemSteele Posted October 27, 2020 Topic Author Share Posted October 27, 2020 Thanks for getting back to me. Just saw this, in my rush I grabbed one off of Ebay. I think the right is going by the noise it's making when opening. I'll be sure to reach out to your guy as l would like to try to rebuild the next one. Thanks, RJ Link to comment Share on other sites More sharing options...
