BRD Posted July 17, 2020 Share Posted July 17, 2020 Pressing the light switch button sends power to the headlight and initiates the headlight door motor to start moving and raise or lower the headlight door. 1. What, exactly, causes the headlight door motor to stop moving? (i.e. How does the headlight door motor “know” that door is fully open or closed and to stop turning?) 2. Does the motor/headlight send a signal to headlight door control module when headlight door is fully open or closed? Thanks! BRD Link to comment Share on other sites More sharing options...
2seater Posted July 17, 2020 Share Posted July 17, 2020 I don't remember the technical aspects of it but it is essentially feedback load sensing in the module. There are no sensors in the motor itself that I am aware of and will run forever if fed continuous power. There is a timer in the module that will shut the motor off after a period of time if something breaks, or the actuator arm on the motor fails. 1 Link to comment Share on other sites More sharing options...
BRD Posted July 17, 2020 Topic Author Share Posted July 17, 2020 Thanks 2seater! Link to comment Share on other sites More sharing options...
