Bertimus Posted January 4, 2021 Share Posted January 4, 2021 (edited) One of my hubcaps (the center circular cap) is wiggling quite a bit, I was wondering how it's tightened? I've included a picture to show the style of hubcap. Thanks! Edited January 4, 2021 by Bertimus Link to comment Share on other sites More sharing options...
2seater Posted January 4, 2021 Share Posted January 4, 2021 Are you asking about the "R" emblem in the center, or the entire cap that pries off to expose the lug nuts? If it is the entire cap, that would be odd as it is a sort of friction fit. Is the steel spring in the correct place inside the cap? I have seen the metal outer casing, the shiny part you see, become loose on the black or gray plastic body. It is crimped around the edges of the cap. I have never actually repaired one like that if it is the issue so I hesitate to suggest what may work. 1 1 Link to comment Share on other sites More sharing options...
Bertimus Posted January 8, 2021 Topic Author Share Posted January 8, 2021 On 1/4/2021 at 5:34 AM, 2seater said: Are you asking about the "R" emblem in the center, or the entire cap that pries off to expose the lug nuts? If it is the entire cap, that would be odd as it is a sort of friction fit. Is the steel spring in the correct place inside the cap? I have seen the metal outer casing, the shiny part you see, become loose on the black or gray plastic body. It is crimped around the edges of the cap. I have never actually repaired one like that if it is the issue so I hesitate to suggest what may work. The entire cap! Link to comment Share on other sites More sharing options...
