Brake conversion
richard
I like the Teves and have a few spares but understand the regular power brake from a 89 Riviera is plug and pray.
I'm sorry to say that retiredmechanic74 hasn't been on the forum since 2019. I hope he sees this and gives you a response but it is doubtful. I would be leery of using compression fittings on brakes although the Amazon seller says they will work. I think flared fittings would be a better choice even if they are a little harder to work with.
Agree, with flared fittings it is locked mechanically and not a slip grip.
Reccomendations on a brand or type?
Are they all about the same brandwise?
I don't understand the question? If referring to joining brake lines, the entire brake system on the Reatta is metric bubble flare, most being M10 x 1.0 fittings. This type of flare is easy to make, even working in place under the car. Couplings are easily available and is the only way I join brake lines. As for brand, the last order I bought was 4Lifetimelines on Amazon, but a FLAPS will have them also.
