Alchemy333 Posted March 12, 2023 Share Posted March 12, 2023 Pretty self explanatory. They are 1/4" longer than OEM. Need to purchase 1/4" plexiglass, and longer bolts. The mounting holes have a metal sleeve, that can either be ground down, or as i did, ground out so the spacer lays flat. The clearance is slightly larger than a razor blade... should be sufficient. The right side sensor can be used also on the left side. It will be about a week before I get the rest of the suspension work completed and I will update on performance and function. 5 Link to comment Share on other sites More sharing options...
DAVES89 Posted October 6, 2023 Share Posted October 6, 2023 I too bought the right side but I think the left will be a better fit. I will be ordering the left side next time. My buddy Bob, who is a machinist made them for me. He had some plastic material that was just too thin so used a fender washer for extra thickness. He kept using a micrometer to get the exact thickness. Your picture makes me think that the lead is a bit stretched, which because being the machinist he is made the spacer a bit different then yours. Mine fits perfectly and works great. I had been dealing with the drivers front going intermittent [I could tell because I could feel the pulsation from the right front]. When I removed it the lead was frayed and "looked" worn out. Going to order 2 more for the 'vert! 1 Link to comment Share on other sites More sharing options...
