AZ Ron Posted March 4, 2017 Share Posted March 4, 2017 Great dealing with this supplier. Cost me $155 shipped and was a relatively easy install. It charged up in 64 seconds and does not leak. No test drive yet as I have to install a different damper on the crank snout before doing a test drive. Just a couple notes. I only lifted the plastic cover at the base of the windshield and moved it to the rear on the driver's side. Also the same thing on the shock tower brace. I lifted it up and stuck a rubber mallet in there to keep it out of the way. I never loosened any bolts on the passenger side. I wedged a block of wood between the master cylinder and the shock tower so I could use vice grips to remove the old ball as it was on there very tight. I did not have the proper size allen wrench. I was afraid that I might damage something as the cylinder has quite a bit of movement. My strap wrench would not budge it. Spinning Wheels has more of these in stock if you want one. No clearance issues at all. Pics to follow. Link to comment Share on other sites More sharing options...
Ronnie Posted March 4, 2017 Share Posted March 4, 2017 It's good to know they are still selling them at a reasonable price. Thanks for posting. Link to comment Share on other sites More sharing options...
