Philbo Posted February 15, 2021 Share Posted February 15, 2021 Hey guys, I have had this issue on my reatta since I bought it. The transmission works very well in all aspects (shifts smoothly etc.) except sometimes (and it's not every time) if I floor it and take it all the way up to red line, it just doesn't shift and the engine will bounce off the rev limiter. My solution to the problem has been just to not floor it (not very often at least ?) but I would like to know why it does this and how to fix it if possible. Has anyone else had this issue? Thanks! Link to comment Share on other sites More sharing options...
Ronnie Posted February 15, 2021 Share Posted February 15, 2021 My guess would be that your TV (Throttle Valve) cable is slightly out of adjustment. 1 Link to comment Share on other sites More sharing options...
Philbo Posted February 15, 2021 Topic Author Share Posted February 15, 2021 Ok I'll look into it. Do you know if that is something that is fairly easy to do on your own? Link to comment Share on other sites More sharing options...
Ronnie Posted February 15, 2021 Share Posted February 15, 2021 It's an easy job. If you have a service manual instructions should be in section 7A. 1 1 Link to comment Share on other sites More sharing options...
