Reatta Owners Journal
The Teves ABS Brake system was used on the vehicles listed below.
The Teves Brake system was standard equipment on some of the cars in the list. In most of the cars listed below, the ABS was an option. So don't get discouraged if you find a few cars that don't have it.
Compatibility Chart
MakeModelYearDrive TypeNotes
Buick Electra 1989   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Buick Electra 1990   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Buick LeSabre 1989 Front-Wheel Drive ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Buick LeSabre 1990 Front-Wheel Drive ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Buick Reatta 1989   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Buick Reatta 1990   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Buick Riviera 1989   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Buick Riviera 1990   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Cadillac Commercial Chassis 1989   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac Commercial Chassis 1990   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac DeVille 1989   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac DeVille 1990   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac Eldorado 1989   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Cadillac Eldorado 1990   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Cadillac Fleetwood 1989   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac Fleetwood 1990   ANTI-LOCK DISC/DRUM BRK(JM4)
Cadillac Seville 1989   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Cadillac Seville 1990   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Oldsmobile 98 1989   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Oldsmobile 98 1990   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Oldsmobile Delta 88 1989   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Oldsmobile Delta 88 1990   ANTI-LOCK DISC/DRUM BRK(JM4)~ - W/HI PRESS WARNING SW
Oldsmobile Toronado 1989   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Oldsmobile Toronado 1990   w/PRESS WARNING SW - FRONT & ANTI-LOCK BRK(JL9)
Pontiac Bonneville 1989   w/HI PRESS WARNING SW - ANTI-LOCK DISC/DRUM BRK(JM4)
