Pre-buy inspection
Giacomo
Hi Guys,
may I ask your help in the purchase process?
In Switzerland are only a handful of these beauties Running and I‘m short before getting the only one available for sale.
It‘s a 89er with about 60k miles which passed the Veteran check last year in Switzerland without problems. What I found out so far that tape deck is defect and the headliner is not in the best condition.
I‘m not sure about rust, is that a common issue? I just saw a few spots underfloor.
is there anything I should check more specifically?
Thanks for your advice
BR Giacomo
Link to post
Ronnie
Welcome to the forum! A bad tape deck is a common problem. They can be repaired but most people don't. A Reatta had a very good paint job from the factory, including dipping the body in primer, so I don't consider them prone to rusting and they are probably above average in that respect. However, the underside of the car is where you should check closely for rust, especially where the engine cradle mounts to the body. The photo below will explain why.
Here is a list of things to check that might help you. What should I check when buying a Reatta?
Link to post
Giacomo
Thanks Ronnie,
good advices. Tomorrow I‘got the next meeting with the owner, keep you updated.
Btw. I found a Reatta supercharged in Switzerland for sale for about 5500 $
Cheers
Giacomo
Link to post
Giacomo
Finally the car looks good....thanks for your support, Ronnie
Link to post
DAVES89
That is a very clean car. Good for you!
Link to post
Ronnie
Nice looking Reatta. I like the color.
Link to post
Giacomo
Two things to be replaced, the cassette deck and the right wing mirror. Anything else in a solid condition
Link to post
2seater
Looks most excellent! Congratulations and welcome.
Link to post
