Doug Posted March 7, 2020 Share Posted March 7, 2020 Recently I ran the driver's side seat of my wife's '90 Reatta as far forward as it would go. When I tried to run it back to it's original position it would not move. All of the other functions worked. I pulled the 4 bolts that hold the seat itself to the rack assembly (not fun with the seat forward) and removed it. After determining which motor did what, I was ready to start pulling plugs to find a way to put 12 volts to the motor that moves the seat fore and aft. Before doing that I tapped the top of that motor with a screwdriver handle. I moved the control toggle back and everything worked. This motor can easily be seen under the seat with everything in place. It lays flat and the end I tapped will be facing you if you look under the seat from the rear without removing anything. Try this before you turn the first wrench. 1 Link to comment Share on other sites More sharing options...
Ronnie Posted March 7, 2020 Share Posted March 7, 2020 Welcome to the forum Doug and thanks for the tip!! Link to comment Share on other sites More sharing options...
