Philbo Posted February 22, 2020 Share Posted February 22, 2020 So getting ready to do a trans fluid change. I was planning on just dropping the pan, replacing the filter and then topping off. The owners manual says to use Dexron II or equivalent. Should I use Dexron III or Mercon V? I was going to use Dex III, but the Bottle for Mercon V says compatible with Dexron II. I think I saw someone on a different forum say not to use the Mercon. What do you all suggest? Link to comment Share on other sites More sharing options...
2seater Posted February 22, 2020 Share Posted February 22, 2020 I am sure there are many opinions as there are on spark plugs, engine oil etc...but unless price is a big difference, hard to go wrong with the Dexron. Some people use Type F, used in older Fords, to firm up shifts, but unless there is an existing issue with the trans. using the OEM recommended fluid makes sense to me. 1 1 Link to comment Share on other sites More sharing options...
Philbo Posted February 22, 2020 Topic Author Share Posted February 22, 2020 I found this interesting and helpful article about different ATFs: https://www.cartechbooks.com/techtips/autotransfluid Link to comment Share on other sites More sharing options...
2seater Posted February 23, 2020 Share Posted February 23, 2020 1 hour ago, Philbo said: I found this interesting and helpful article about different ATFs: https://www.cartechbooks.com/techtips/autotransfluid Good info. Thanks Link to comment Share on other sites More sharing options...
DAVES89 Posted February 23, 2020 Share Posted February 23, 2020 I buy mine from Menards [ a big box retailer in my area]. It is called Dex-Merc and I think is made by Valvoline and comes in a blue bottle. It is Dexron III compatible, which means that it works in all transmissions up to grade III. 1 Link to comment Share on other sites More sharing options...
Philbo Posted February 23, 2020 Topic Author Share Posted February 23, 2020 2 hours ago, DAVES89 said: I buy mine from Menards [ a big box retailer in my area]. It is called Dex-Merc and I think is made by Valvoline and comes in a blue bottle. It is Dexron III compatible, which means that it works in all transmissions up to grade III. I think I got the same kind you mention. This stuff Link to comment Share on other sites More sharing options...
DAVES89 Posted February 23, 2020 Share Posted February 23, 2020 That's what I use. 1 Link to comment Share on other sites More sharing options...
