DAVES89 Posted December 23, 2017 Share Posted December 23, 2017 I agree with RM74. Start with a good servo, check the vacuum lines, in other words do the simple things first. In my history of repairs I always go with the assumption the wiring is good but the end component is bad. Has always served me well except for one thing. A bad relay plug in the console fuse box on the Black. It caused an intermittent failure of the headlights to work. BTW on the Reatta the cruise comes on at 25 mph. Link to comment Share on other sites More sharing options...
fordrodsteven Posted December 23, 2017 Share Posted December 23, 2017 Captmike, Be careful when backfeeding the system you can create more problems. If you can get a known to be good servo use it in place of the one that's on the car. You could also have a bad brake light switch or porous vacuum line. If my memory serves me right the cruise will not work under 30 mph which means that it is controlled by the grounds of the computer. Also just above the gas pedal is a module that is the power supply, that can also have an effect on the problems your having, but it sounds like the orange wire. I hope I'm wrong. When my cruise didn't work I went step by step as directed in the manual troubleshooting section. I went by the tree (does it work yes , no) which got to the point where it said my problem was the servo. I bought a replacement servo and it was the correct solution. If you have a manual my advice is to go to the troubleshooting section and follow the procedure. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted December 24, 2017 Share Posted December 24, 2017 Captmike did you get the locks and mirrors working ????? Link to comment Share on other sites More sharing options...
Captmike Posted December 27, 2017 Topic Author Share Posted December 27, 2017 Yes that's the bridge. If you expose connector 201 when it is still in place look under it and in the far right corner you will find the orange wire. This wire comes "from" the fuse and not to it, that is why the fuse relating to these problems will check good after I repaired this wire I not only got back door, trunk, and gas tank locks etc. I also got back the ability to control all my lights through the headlight switch instead of the fog light switch. I believe that those repairs came from positioning the copper wires in the c201 connector and sealing the wires with a sealer keeping them from grounding out to the other contacts again. All of those things your fix repaired work fine. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted December 27, 2017 Share Posted December 27, 2017 All of those things your fix repaired work fine. Yes ....I have no more problems. Everything is working as GM intended. Did you get the mirrors and locks working? It is important for us to know. Link to comment Share on other sites More sharing options...
